Antec GX700 - Cooling Performance
Our test kit includes an ATI Radeon HD 5870 2GB Eyefinity 6 graphics card and an Intel Core i7-870 CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.305V and a CPU PLL of 1.9V. This is a modest overclock, but our test kit will spend most of its life under high load, so pushing it too far isn't in anybody's interests. More importantly, some poorer-performing cases push the CPU temperature to above 80°C, so even this overclock will prove to be too much for some cases.
The CPU is cooled by a Gelid Tranquillo CPU cooler with a Noctua NF-S12B ULN 120mm fan. The NF-S12B ULN is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also locked the fan speed on the graphics card to 30 per cent to prevent the automatic speed control interfering with the results.
We record the temperature of the CPU using
RealTemp, noting the temperature of the hottest core, and used
GPU-Z to log the temperature of the graphics card. Having recorded the ambient temperature in front of the main air intake of each case, we're then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware. To load the system, we use a combination of the Canyon Flight benchmark in 3DMark06 and the smallfft test in Prime 95.
- CPU:
  Intel Core i7-870 CPU overclocked to 3.4GHz
- Graphics card: ATI Radeon HD 5870 2GB Eyefinity 6
 - Motherboard: Biostar TPower I55
 - RAM: 2 x 2GB OCZ 1,866MHz DDR3
 - Hard drive:  160GB Seagate Barracuda 7200.9
 - Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
 - Power supply: Seasonic M12D SS-850EM
        SilverStone Temjin TJ11 (Full speed)
        SilverStone FT02R-W (Full Speed)
        SilverStone Temjin TJ11 (Minimum Speed)
        SilverStone FT02R-W (Minimum Speed)
        SilverStone Raven RV02 (High Speed)
        Antec One
        Fractal Design Core 3000 (Maximum Speed)
        Cooler Master HAF X
        SilverStone Raven RV02 (Low Speed)
        NZXT Switch 810
        NZXT Source 210 Elite
        NZXT Phantom 630 (Maximum Speed; Drive Cage Removed)
        NZXT Phantom 820 (Maximum Speed)
        Cooler Master HAF XM
        Cooler Master CM 690 II (Full Speed)
        BitFenix Shinobi XL
        Xigmatek Elysium
        In-Win GRone (Maximum Speed)
        Antec GX700 (Two Fans; Maximum Speed)
        Corsair 550D (without panels)
        Fractal Design Core 3000 (Minimum Speed)
        Fractal Design Define R4 (Full Speed)
        Cooler Master HAF 912
        Antec P280 (Maximum speed)
        Lian Li PC-A76
        NZXT Phantom 630 (Minimum Speed)
        NZXT Phantom 820 (Minimum Speed)
        Cooler Master CM 690 II (Minimum Speed)
        Antec P280 (Minimum speed)
        Xigmatek Midgard II (Maximum Speed; Drive Cage Removed)
        Antec GX700 (Maximum Speed)
        Thermaltake Chaser A31
        Aerocool X-Predator X1 (Maximum Speed)
        Sharkoon T28
        In-Win GRone (Minimum Speed)
        Corsair 550D (with panels)
        Nanoxia Deep Silence 1 (Maximum Speed; Ventilated)
        Corsair Carbide 200R
        CM Storm Scout 2
        Xigmatek Midgard II (Minimum Speed)
        Aerocool X-Predator X1 (Minimum Speed)
        Fractal Design Define R4 (Minimum Speed)
        Antec GX700 (Minimum Speed)
        Nanoxia Deep Silence 1 (Minimum Speed)
        Antec GX700 (Fans Off)
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
        Cooler Master HAF X
        SilverStone Temjin TJ11 (minimum speed)
        SilverStone Raven RV02 (Full Speed)
        SilverStone Raven RV02 (Minimum Speed)
        Xigmatek Elysium
        Antec One
        NZXT Switch 810
        Sharkoon T28
        BitFenix Shinobi XL
        Lian Li PC-A76
        CM Storm Scout 2
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
Read our
performance analysis on the next page.
